Beru Spark Plug Extensions
Hello to All
Could anyone please advise me of a part number &/or supplier for the threaded crimp-on spark plug lead for a Beru spark plug extension (from a 1970 2.2L engine) as per this photo: http://forums.pelicanparts.com/uploa...1630360306.jpg I also need a replacement part number for the accompanying extension as per the photo below to suit the same threaded crimp-on plug wire end. The type offered by Pelican seem to be of the “wood screw” style of end fitting. http://forums.pelicanparts.com/uploa...1630360422.jpg Any info or advice you can forward to me will be most appreciated & helpful - Thank you in advance. Cheers JB |
The stock 70 Beru connectors do not have the crimp end. Unscrew the wire lead and you will find a "wood screw" terminator inside the connector. Just screw in new wires. Simple.
if your car has updated Beru connectors this is a Mercedes PN 0001591438 - BERU RHB003. You will need a special crimper to do this properly. There is s lead crimp on the small shank and secondary crimp to secure the wire insulation in the outer collar. |
Pelican lists them. Just ordered 100. I like to make my own wire sets.
| All times are GMT -8. The time now is 11:24 AM. |
