Focus 9 Technology solid-State DME relay (Pump-Prime)
1988 3.2, I bought the Porsche solid-State DME relay (Pump-Prime) from Focus 9 Technology but never installed it until last night. Ultra simple to install and the good one went into the glove box. I also figured out that if I have to change the relay, I don't have to unbolt it. Just unplug the relay and install the spare into the plug and leave the "old" one bolted to the floor. Clean up the installation later.
You can hear the 3 seconds of prime after the the key is turned to on. Neat. You might have to turn up the volume way up to hear the pump but you get to hear a 3.2 with a H&K pre muffler and single in and single out muffler. I think the car runs a little better but I bet that is because I installed something new....
https://www.youtube.com/watch?v=LEyN2052RBg
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 09-01-2021, 05:57 PM
Just be careful not to use the prime feature when the engine is cold. Rather, turn the key all the way and let the engine crank to build oil pressure. Otherwise you risk staying the engine before oil had circulated,!eading to damage.
Pump prime is a great feature to use when the engine is warm. It saves battery power.
Old 09-01-2021, 09:59 PM
Racer
winders's Avatar
I don't know where this idea comes from. Priming the fuel system is fine with the engine warm or cold.........heck, we even do this on our race cars and often use check valves to keep the pressure in the system after we shut everything off.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 09-01-2021, 10:44 PM
Diss Member
Quicksilver's Avatar
Like winders said. A 3.2 with out issues will fire up as soon as it rotates past the TDC reference center. If it doesn't instantly start there is an issue that should be chased down.
Also if everything is correct on a 3.2 there is already pressure retained in the fuel rails so the "pump prime" doesn't really have anything to do. If the pressure retention valve has "degraded" the pump prime would be a good way to keep from having to replace the valve. (Isn't it NLA now?)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-02-2021, 03:09 AM
Interesting, because my 3.2 use to start almost instantly. Now it requires some turns before it starts, especially after sitting for a while. That's why I thought I would try the new relay.
1988 Carrera coupe
1966 250 Ducati
2021 VW Golf TSI
2014 Ninja 300
Old 09-02-2021, 08:14 AM
