Removing rear seats-Can't get large screws off
I'm trying to take out the rear seats. The backs are a problem as I can't move the large screws holding them in. I put a little pb blaster on them. I've tried screw drivers (not big enough), a flattened washer ( bent it) and nothing worked.
Any help in getting these loose would be appreciated. I don't want to use the equivalent of a BFH on these. Thanks. Dave
Dave Ploss '87 911 Carrera Coupe - Black '90 Mercedes 190E '00 Filippi Lightweight Double |
mine were also on very tight.. I think the thread gets weathered from under the tub.. I used a 1/2in socket screwdriver. I used another large screwdriver and baby sledge to slam the screw a few times first...........Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Dave,
These screws are notorious - most are frozen, for some strange reason. An impact driver saved me - $25 Husky tool from Home Depot.
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
I had the same problem with mine. Once I had them out I went to a local specialty tool shop and spent .50 for some new ones with allen heads. Works much better now.
Dan Byers |
Senior Member
Soak 'em with a little PB Blaster, and then use the m/c impact driver as mentioned above.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
The problem is getting enough torque. Here is a way to do it with tools you probably already have.
Firstly you need a really big flat blade screw driver. Put the blade in the screw head. Then take an adjustable wrench and snug it down on the flat blade, like a "T" handle. Crank away.
Chuck Moreland - elephantracing.com - vonnen.com |
What Chuck said, worked for me a few weeks ago.
Guys,
Thanks alot. Most times you think you are the only one that had a problem like this. I know I'm not alone. Dave
A good tool for this is a drag link socket. Its basically a socket driver with a large flat head screwdriver bit on the end. It allows you to use your socket wrench and all its torque to get the bolt out. I couldn't remove mine either, used the right tool, and out it came. You can pick one up at Craftsman.com. Most stores will not stock it.
1983 911 3.6L - NASA GTS-3 class 1998 Boxster - PCA SpecBoxster, NASA GTS-2 2003 996X51 - NASA GTS-4, PCA GTB 2003 996 Carrera 2 Coupe 2003 Ferrari 575M |
Yes, also you can gind the drag link socket to fit the slot exactly. Then use impact or make own impact with a hammer.
