Compression Test + Leak Down Process?
Hello Pelicans,
I want to do a compression test and leak-down test. The proposed sequence: 1 - warm up engine 2 - remove AC compressor/etc. 3 - remove all plugs 4 - compression test cyl. 1 then leak-down test cyl. 1 5 - do #4 until all 6 are done 6 - install new plugs 7 - install other stuff The question is should I do all the cyls. compression test and then go back and do the leak-down tests? The means I would have to thread in the Stomski extender again on all cylinders. The leak-down test might take a while because I will have to adjust the pressure on the incoming gauge if the regulator doesn't keep it right on. I plan to test with 80psi on the incoming gauge. I'll calculate the % after to compensate for not using 100psi. Thanks. -Henry |
Following….
okay - I'll post results here.
It seems the people on BaT want both and having a record of results might help others. |
If you want to follow along.... I started a thread here.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/1102537-need-advice-leak-down-great-compression-test-not-so-much.html#post11461512 |
The engine says hot for a long time so rushing is not really needed. Getting the plugs out and having a setup to make the leak-down and compression tests get connected to gauges that work is needed.
I was told that you do a leak down test stone cold.
I don't do either hot.
for one its a pain working on a hot motor. two what about temp differences from start to finish. not worth it in my opinion. people also say to hold the throttle wide open. I never see any difference. as long as you do them all the same way is what matters. I would check head bolts and do a valve adjustment first. just check to see if any are broken. pull the fuel pump relay |
| All times are GMT -8. The time now is 08:23 PM. |
