Correct TBs and Shocks for 2000 lb. Car?
Any input appreciated. 2,000 lb. Car 70% street 30% canyon carver / autocross. 20mm Tarrett sways front and rear. Bilstein sport shocks front and rear. Running 9x17s and 11x17s. 225/45-17 - 275/45-17
PRO Motorsports
21 front 26 rear would be my recommendation.
People tend to overdo spring rates on street cars, thinking they’re getting more for their money going bigger.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Thanks Tyson, I was going to call you tomorrow and ask you. All good now. You wouldn't happen to have some 21mm laying around? Or maybe do a trade for the 23mm
Just for another point of reference-
2400 lb 20f 27r torsion bars 22f 19r Tarett sways, set soft Digressive Bilstiens valved to my weight and spring rate. 90% rough back country canyons and couldn't be happier with the ride. Minimal body roll, front end is planted, excellent turn in. Have yet to get the rear end loose (saving that for a track day). Last edited by Solamar; 10-03-2021 at 02:01 PM.. |
Functionista
And another....
2200lbs 19f 26r 911 Clubsport bars 22mm f&r Acceptable corner balance but not perfect Will only rotate mid-corner with aggressive acceleration or a major throttle pedal release.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
About 25.25" at front fender. I am not able to see or feel any suspension travel when I put my body weight on the front bumper, I doubt that is a realistic way to judge suspension health. BTW, I have poly bronze a arm bushings and with the tbar removed and shock disconnected I have verified free suspension movement. |
911 Slant, based on your wheel description, you have a wide body car. Is it running early steel trailing arms, aluminum trailing arms or 930 arms? What is your threshold for comfort? Are you interested in valving the shocks/struts?
What bars are in it right now? How do you like the handling/ride balance? What specifically are you wanting to change in that regard? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
scumbag
My car is a little heavier at 2250, but I run 21/31 with Von shocks. (L2 f, L3 r)
It's compliant enough for the street that my wife doesn't complain.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
scumbag
At present, I have the 915 Carrera bars. (21/20, I think)
But I have Elephant RSR adjustables waiting for me to install if/when I get over being lazy. EDIT: It's probably worth noting that my car is SC width, pretty low (23 7/8" ground to fender up front, 24 1/8 rear), has raised spindles, and lengthened LCAs.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b Last edited by chrisbalich; 10-04-2021 at 05:09 AM.. |
Pretty stiff 23/30 is race car territory
Insert Tag Line HERE.....
I always run 23/31... So what if it rides a little stiff on the street? It'll be just right when you need it the most - on the twisties and for AX..
Marc |
I have a set of 86 930 bars in the attic .
If you’re interested in trying them out , let me know and I will dig them out . They’re yours if you come collect them from south oc (Laguna hills) Iirc they 19-26 , and could give a good impression on a car your weight to compare with what you have now . If you can do your own install it will be an easy way to work out what you need … Note : I’m not a big fan of using used/unknown parts like suspension without a thorough inspection but you should/could be good for a few weekend blasts . |
Tyson is a lot more qualified than me but I prefer 19/26 over 21/26 in an early car. I've driven that in auto-x and its excellent, just have to power out of the skids.
I have 21/29 now.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
I am guessing a wee bit of understeer as well? Slightly softer front torsion bar would likely help. Cheers
Jeff, you are correct. Hopefully 21mm front torsion bars will do the job.
Consider the Bilstein shocks from Rebel Racing. RR, via Bilstein, offers custom steel bodied shocks built per your car specs (ride height, vehicle weight, spring rates, type of driving, etc.). Optional adapters for adding coil-overs as well.
![]() Sherwood (no affiliation) |
