-   -   Need help getting a firm pedal (http://forums.pelicanparts.com/porsche-911-technical-forum/1101817-need-help-getting-firm-pedal.html)
stownsen914 09-12-2021 05:15 PM
When I need to prime the entire system, I usually start by filling the reservoir, crack an outer bleeder at one corner, and let gravity do its thing for a while. It takes a while, but after a while gravity seems to do its thing. Sometimes you need to pump the pedal to stir things a bit. You'll need to do the same at each corner to get the air out.
I always work solo, and it works for me.
TT Oversteer 09-12-2021 07:35 PM
Replace the master cylinder
hunter92040 09-18-2021 03:04 PM
Update
Thank you all for the advice. I had my wife pump faster and hold it. I got all air out. Now I have a firm pedal and she's on all fours.
Next project: trouble shoot why both windows don't work.http://forums.pelicanparts.com/uploa...1632006206.jpg
Harpo 09-19-2021 06:03 AM
Yes, it is possible. Many decades ago I installed them upside down and then very carefully drove it on back roads to the brake shop. I felt so stupid
Originally Posted by Jeff Higgins (Post 11451946)
Is it even possible to install them upside down? I guess I never thought about that. I suspect the fact that the brake line wouldn't reach might be a pretty ready indication all was not well, assuming we could even get that far.
