Chip on Fan Blade - Concern or small enough to leave?
Hi everyone,
My fan has been chipped due to my own stupidity. The chip is rather small but am wondering if there would be any concern in putting the fan back on the car as is?
Thanks in advance
Old 09-12-2021, 07:24 PM
The voices in my head are saying
'JB Weld'.
_______________________________________________
45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop.
Old 09-12-2021, 07:33 PM
pete3799's Avatar
Put it back on.
Pete
79 911SC RoW
Thanks for the replies! I'll clean it up nicely and put her back. The chip that came off was almost weightless and don't think it will throw off the balance.
Old 09-12-2021, 07:35 PM
stick a breaker bar in the fan to loosen the nut? Ask me how I know...... If you have the missing piece just JB Weld it in place and party on!
Old 09-12-2021, 08:32 PM
Looks like a Phillips screw driver, #4 I'd say, Craftsman.
Clean & eyeball the blade real good for any hairline fractures. Oh, buy the proper tool.
Old 09-12-2021, 09:35 PM
Still here
pmax's Avatar
Interesting how the outside surface's all smooth but the other pitting.
Old 09-12-2021, 09:42 PM
Bill Douglas's Avatar
Ah, previous owner - can never trust them LOL
If it's catching your eye, as 87 said a bit of JB Weld, and enjoy the car.
Old 09-12-2021, 09:57 PM
Get a New Fan, install properly. This happened around 1200rpm, I shudder to think of this happening at freeway speeds when the fans doing around 5-6,000rpm.
https://www.flickr.com/photos/2010-2011_european_tour/albums/72157644084433382
At the least, get the balance checked.
Old 09-13-2021, 02:59 PM
I weld repair them like this all the time. Jb weld is not a good solution
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 09-13-2021, 03:51 PM
I'd contact shawn @ tru-six for a proper repair...you only want to fix the fan blade once - JB weld would probablly hold for some time > but it's not a permanent fix.
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 09-13-2021, 04:59 PM
Correct no jbweld .. if you look at my website I have this repair listed. Done hundreds of them and do them by TIG welding
Ben
89 944,85.5 944
914-6werkshop.com
Old 09-13-2021, 05:19 PM
Guys, the chip is kinda a big deal. Say it's a 79 911SC with a fan ratio of 1.8:1. At an engine speed of 6000rpm, the fan is turning almost 11,000rpm. Fix it the right way or replace it.
Old 09-13-2021, 06:14 PM
Still here
pmax's Avatar
Really ?
A defect free fan other than one chip like that is fine, leaving cosmetics aside.
Old 09-13-2021, 07:06 PM
If you do decide to use it sans repair you should absolutely radius any fractured edge. This will mitigate, but not eliminate as with a TIG repair, future failure. Use a small Dremel tool or disk to do this. Fractured metal edges will be the first to fail.
Old 09-13-2021, 08:14 PM
tobluforu's Avatar
Leave it be, have a person that knows how to weld since its off, or replace
Old 09-14-2021, 04:35 AM
