-   -   Floating Rotors for Carrera Calipers (http://forums.pelicanparts.com/porsche-911-technical-forum/1102157-floating-rotors-carrera-calipers.html)
speeds5 09-12-2021 08:46 PM
Anyone know of any floating rotors available for Carrera calipers, front and rear? I’m aware of 930 and other options but need same dimensions as stock disks, easy bolt ons.
Quicksilver 09-13-2021 04:37 AM
The 3.2 Carrera's brakes are limited by the rotor mass so there would be no advantage to going to the effort of creating a floating rotor without increasing it's thickness or diameter.
In other words: No.
stownsen914 09-13-2021 04:43 AM
With Carrera size rotors you may not find much advantage in going to floating. But if you really want them, contact Doug Arnao at https://www.vehiclecraft.com/. Most of his stuff is aimed at going larger, but last I knew he was using Coleman rotors which are available in pretty much any size imaginable.
