jmz jmz is online now
jmz's Avatar
what is a good way to clean fuel tank
My car has been layed up for over two years and I will be re-installing the engine etc. in the next week or so. I didn't plan on having it layed up so long so I didn't top off the fuel before I parked it. I am concerned I may have some junk or varnish in there. Is there a good product to run through the tank? I would prefer not to take it out and boil it or anything so drastic as that.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 05-16-2003, 09:15 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
My car sat for 2 years and I lucked out. All I really needed to do was change the filter, drain the tank and flush the old gas out. Pull your gas tank level sender and take a look to see how bad it is first.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-16-2003, 09:22 AM
jmz's Avatar
I can drain the tank ...I made a tool w/ a bolt and a couple of nuts. If there seems to be some varnish and junk what is a good way to flush the tank. ...clean fuel, kerosine ???
Old 05-16-2003, 11:58 AM
Randy Webb's Avatar
remove the float assy & inspect the tank carefully with a light and mirror or a borescope if you have one. The fiber endoscopes that surgeons use are fabulous for this, but I doubt you can get a loaner....
If its nasty in there, you'll need to get the treatments made for this problem from Eastwood or smoe where.
Old 05-16-2003, 03:25 PM
jmz's Avatar
I sell products into surgery centers and have been looking for a scope w/ some broken fibers that are not suitable for medical use. Hopefully everything looks good ...probably will. I replaced the tank about 6 or 7 yrs ago due to rust in my old one.
Old 05-16-2003, 03:56 PM
