G50 gearbox shifter loose on my "88 911 Carrera
Is there a detailed video or tech article that shows how to correct shifting sloppiness in the G 50 gearbox including bushing replacement, etc?
First you have to remove it from the tunnel. Then it's obvious.
Purchase this Porsche JWest Engineering G50 Shifter Bushing Kit from our host, it has great instructions
nomata, check out the search this thread link above.
Type in g50 shifter loose. You will find much on this subject. |
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Northern Motorhead
I installed the JWest stiffer bushing kit on my 89 and it did make a big difference.Although if i remember drilling out the fasteners for the OEM bushings was painful !
That was a few years ago ...
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
There is so much good advice in that thread- follow all the suggestions. The very last post that reminds you to put it in first or third gear is very important, and get a helper to force the shift rod rearward. Good luck!
This may be helpful as well.
https://www.hagerty.com/media/maintenance-and-tech/make-your-porsche-shifter-feel-like-new-in-one-weekend/ |
