Limited slip differential rebuilt tools
Does anyone know the bolt circle dimensions of the transmission output flange? I want to measure the preload on my limited slip differential
BTW I have a six bolt m8 flange with an od of 101mm
Based on the dimensions from the flange this is what I came up withhttp://forums.pelicanparts.com/uploa...1632059895.jpg
To answer your question, depending on the year and model 100mm or 108mm.
100 mm please
The easiest way is weld a socket on a bar, then u can do any of them, 914, small 911, big 911. No bold pattern necessary.
Here is one from the service manual, local manufacturer. They just run a nut and bolt thru the hole in the middle. http://forums.pelicanparts.com/uploa...1632081430.jpg
How did you cut the square hole in the center?
Thanks, Rahl |
I had 3 of them cut out on a water jet
Nice job!
Rahl |
Anyone have an extra pair of the elastic bolts to sell?
what is the breakaway torque supposed to be? my wheel turns pretty easily by hand with one wheel up and in neutral. I couldnt find anything about it in the books. It seems to work fine when in use. Other limited slips iv worked on were over 100 up to 200
Thanks thats a relief. I was thinking maybe i could test it with a torque wrench on the hub nut but when i gave it a turn by hand I didnt bother
1982 911sc it has the code on it for lsd so its factory
http://forums.pelicanparts.com/uploa...1633199297.jpg By "two disc," I mean a "40%" LSD with one clutch disc on either side of the pack. |
perfect. Great info thank you
| All times are GMT -8. The time now is 01:20 AM. |
