Can a fellow Pelican post bearing shells to UK?
Hi
Long story short, I bought a 1976 911S from this site last year and am part way through a rebuild. I would like to order bearing shells from P.P and send them directly to HM Elliott for a HM30 coating to close up the tolerences. The issue is they don't post to the UK. Would anyone here be able to post them to me if I arrange with HM to post them within the USA? I am bit stuck because without the extra thou of coating I am running close to the lower limit and can't afford a crank regrind at the moment! Cheers Jack |
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
If all else fails I'd be willing to do you a favor.
Behind the Sun
FVDbromabacher in Germany will have what you need and ship
I wouldn’t count on bearing coating to make up for sloppy bearings.
why don`t use the England`s supplier no tax for import to you..cheaper post cost as well
Ivan
Thanks I think I am sorted now.
I can get the bearings in the UK but want to try the HM Elliott coating hence easier / cheaper to buy in the USA and send directly to them. The car was running ok oil pressure etc before the piston went (silicon sealant blocked oil jets) so I am reasonably happy to chuck the crank back in with new shells. It might work, it might not but it is a punt I am willing to take. Thanks. |
