FYI Odometer gear Euro and USA are same
My odometer gear crumpled last fall. When getting replacement gear I didn’t know which to get or what was different between the 20x30 USA vs EURO and my disintegrated gear gave no answers. After getting both versions my calipers tell me that there is no difference
I’ll upload a photo later, I can’t seem to do photos from an iPhone Sierra madre part # OM 066 OM 021 76-89 20x30 gear |
PCA Member since 1988
Count the teeth too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
They are both 20x30.
The one thought I had was that the dimensions of the teeth would be different. But they are not, or at least If there is a difference it’s within manufacturing spec I believe that the difference between US and Euro gauges is simply in the gauge face being in Km/h or mph |
Gilles RoW 88 Carrera coupé |
I'm scratching my head too, I bet there's an 80 year old guy named Torsten who could tell us.
But the ODO gear that disintegrates are the same. These are the Euro an the US gears from SIERRA MADRE ![]() Again, my confusion was because my car was a RoW imported and I had know idea where that speedo came from, all I knew was that it was 20x30 Last edited by Mtsurfposse; 04-12-2025 at 12:52 PM.. |
Couldnt post two pics in one comment section? my bad, I didnt wait
The gears for KM and Miles are not the same. I'm out of town for a couple of weeks so I don't have my notes, but there are a couple of different gear configurations for the KM speedos. If you count the number of teeth on the center gear and reach out to the guys at odometer gears they can tell you what primary gear you need
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
This eBay store sells a bunch of different odometer gears and conversion kits. Probably some clues in here.
Mark
1979 911SC Targa |
