mtl911sc's Avatar
Sunday afternoon suspension mystery for ya
After doing some suspension work on & off over the past year or two, finally got down to a basic alignment…and noticed this:
Top pic is the passenger front wheel, which is too far forward in the wheel well. Bottom pic is the driver front wheel, which is pretty much centered.
Unfortunately I can’t remember whether the difference was there before the car went into my garage for an extended period, but regardless I need to fix it. Struts, ball joints, tie rods, all bushings, wheel bearings are all new. Do I have something installed incorrectly?
Tried playing with caster as well, but any adjustment that can be made at the strut top mount is tiny.
Old 09-19-2021, 09:52 AM
Flat Six
Flat Six's Avatar
Picture didn't post . . . .
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 09-19-2021, 10:01 AM
Tape measure will give you a rough comparison, could be fender? Or wheelbase from rear wheel? If it is the front end start measuring tub attachment points.
Old 09-19-2021, 11:42 AM
Agree,,,,start measuring tub points to wheel. Axle to axle as well Measure a lot! Inspect your struts, mine was bent outward and I couldn't get camber alignment. You should be able to visualize the top of your shock tower positions to see if you are off. Measure these as well...
Old 09-19-2021, 01:51 PM
mtl911sc's Avatar
Here’s a pic before I made any changes to the car. Wheel position was fine on that side and the car has not been driven much since and no accidents either…so even though all input is appreciated I don’t think taking tub measurements etc will get me any closer to solving this issue?
Old 09-19-2021, 05:25 PM
mtl911sc's Avatar
Struts are brand new from Elephant Racing.
Old 09-19-2021, 05:27 PM
Is the a arm all the way back against the cross-member?
206 637 4071
Old 09-20-2021, 03:36 AM
Have you driven it already and did it feel okay?
The only things I can think of are the a-arm being too far forward like John said (which means the bushings weren't seated right or there's something seriously wrong with the front mounting of the a-arm), or that you bought and somehow installed elephant racing's de-cambered ball joint 90 degrees off, where the base of the strut would be half an inch forward in the car. I would say the second option should be physically impossible, but I could see a way in which somehow could really blow it and then tighten that nut down anyway.
Man, that's such a stretch. If you ever listened to Car Talk on NPR they would have said it's booOOOOgus.
1982 911SC
Old 09-20-2021, 05:24 AM
mtl911sc's Avatar
Both sides look about the same to me, however it was my first time reinstalling A arms so I can’t be sure that I installed correctly. What would be the easiest way to try and move the A arm back further towards the crossmember? Can I simply loosen the front mount, or does the wheel need to come off and the strut loosened at the top mount?
Passenger side
Driver side
Passenger side
Driver side
Passenger side
Driver side
Old 09-20-2021, 10:06 AM
I flipped one of the a-arm shots and compared it against the other. The angle of the front mounts isn't the same (one dips up, one dips down). The front mount on the passenger side is also not torqued up, look at the gap on the washer. That could impact the wheel position or indicate a different problem if you can't tighten it all the way. Whether it's the whole issue isn't sure but definitely take care of that.
Originally Posted by mtl911sc View Post
Passenger side
1982 911SC
Old 09-20-2021, 10:53 AM
mtl911sc's Avatar
Whoops my bad, posted a pic of the passenger front mount after I’d loosened it. Here it is torqued up:
Old 09-20-2021, 11:16 AM
mtl911sc's Avatar
Is it possible that I have a bent control arm which can’t be detected by eye?
I’ve had this car for almost 15 years and have tracked it in the past - no handling issues and no accidents whatsoever while I’ve owned it. Nor was any problem picked up when the car was inspected prior to track events.
Old 09-21-2021, 05:46 AM
proporsche's Avatar
what is that ring with lubrication nipple..never seen that -not an original part..aftermarket supplier?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-21-2021, 08:26 AM
Ivan
It looks like the Elephant racing Polybronze bearing. I have them installed, but that gap from the goldish ring and the steel bracket is much closer on mine. I suspect that's where the problem is
Old 09-21-2021, 08:28 AM
OffCamber00's Avatar
Ivan
Those are Elephant Racing poly bronze bushings
Mat P
1988 911 Carrera
Old 09-21-2021, 08:29 AM
Diss Member
Quicksilver's Avatar
Ivan
Elephant Racing Poly Bronze
https://www.pelicanparts.com/More_Info/ERMP2051500.htm
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-21-2021, 08:32 AM
proporsche's Avatar
ok thanx...still something is not right on the assembly ...
Ivan
Old 09-21-2021, 08:33 AM
mtl911sc's Avatar
Thanks for the input everyone.
Yeah they are indeed the polybronze bushings. Was staring at my suspension yesterday and the thing is that if they are not installed fully, it’s the same case on both sides since the gap is the same. So why is there such a difference with the wheel to fender clearance?
Old 09-21-2021, 08:37 AM
Elephant Racing front bushings are thicker due to the grease fitting. My Rebel racing RSR front bushings are more flush.
mtl911sc's Avatar
Alistair which bracket are you referring to: the front mount, rear mount at the crossmember, or the ring/flange that's part of the control arm?
1980 911SC
Old 09-21-2021, 08:44 AM
