86-89 Side Vents & AC
First thank you to everyone for posting your AC stories to the forums. I have found them to be a big help. I have a pretty good idea of the pros and cons of different setups (Classic Retrofit vs. Griffiths; running several condensers in series; window tinting; etc).
I have one question for those who were able to get a good outcome of there AC setups.
I realize that the side vents on the 86-89 911s were larger and could swivel. For those that were able to get good cabin temps in really hot climates, how much of a difference do you feel this additional air flow made? In your opinion would it be worth it to hold out for a car with the bigger side flow vents or do you feel they were marginal in your success in cooling your car? I would be willing to use Classic Retrofit's under dash ducts (they seem to be small and less visible) if you think they would help.
Thanks in advance for you input.
Old 09-26-2021, 03:35 PM
