-   -   CIS without the computer (http://forums.pelicanparts.com/porsche-911-technical-forum/1103504-cis-without-computer.html)
Sigurd 10-02-2021 09:39 AM
Can I get the CIS system to run without the computer? I have a 3.0 engine, 930/03 without a CIS system. I found a system for a Lambda equipped engine but I do not have the computer for it. Is it possible to get to work?
boyt911sc 10-02-2021 10:30 AM
930/03 Engine........
Sigurd,
The 930/03 motor did NOT come with the lambda system. You need to look for ‘78~’79 CIS unit with 39-mm intake runners (-4R), WUR-045/-069, FD-031, and other related CIS components.
Tony
timmy2 10-02-2021 10:59 AM
Tony, you forgot the word NOT between did and come in your first sentence…
The rest of your post is correct as usual.
He needs a 78/79 CIS system with the larger diameter runners.
The US Lambda CIS systems are not compatible with the 930/03 engine.
boyt911sc 10-02-2021 11:59 AM
Good eye......
Dennis,
Thanks for catching the mistake.
Tony
fanaudical 10-02-2021 12:41 PM
Sigurd - You might think about replacing the CIS with an EFI ITB kit (since you are starting with nothing) if your local regulations allow it.
I know - heresy from a CIS lover - but if starting from scratch, then I do think that EFI is the way to go now...
timmy2 10-02-2021 01:00 PM
Noticed you are in Norway.
Any CIS system from a European engine will work from 78 to 83 on your 930/03.
Just not the US/CDN/Japan Lambda systems.
