Need help, power windows don't go up.
Hello all, both windows don't go up on my '84 911 cabriolet. I checked the fuse and it wasn't blown. So, I removed the relay from the fog lights and plugged it into the window relay spot. No movement on the driver's side window, but the passenger window started to go up but then the fuse blew....
Could it be a bad switch? bad motor? bad window regulator? |
| All times are GMT -8. The time now is 01:45 AM. |
