Early Porsche 911 trip odometer reset cable
Early Porsche 911 trip odometer reset cable.
There is a small torsion spring that facilitates the return on the knob. The spring on mine is broken, however will the reset still function ? ![]()
Someone must know the answer ,come on guys
Gold71 |
I can’t see that it would not reset, gravity will (should) hold it down but if anything may not allow the trip odometer to calculate fully?
Don’t know until you try it.
Larry 1971 911T 1983 Envemo, Cabriolet 1989 Carrera Cabriolet |
I thought the spring was to there to prevent turning the knurled knob in the wrong direction.
https://www.youtube.com/watch?v=MMKYN9t1FhA go to 1:10 in the video Last edited by thetorch; 10-09-2021 at 01:22 PM.. Reason: added source vid |
