-   -   Engine lid latch tips? (http://forums.pelicanparts.com/porsche-911-technical-forum/1103835-engine-lid-latch-tips.html)
sigchuck 10-06-2021 02:10 PM
Hi guys, I swapped my engine lid and am in the process of trying to install the latch without getting locked out of the engine bay. I tried a search and found a lot of horror stories associated with a bad installation, but not really anything responsive to the right way to make sure the latch is aligned before closing. Is it just a matter of making sure the post is centered in the hole before closing? What about the depth of the post - I'm assuming too much post is worse than not enough insofar as test fitting is concerned?
Thanks for the help and sorry if I missed a thread in searching.
proporsche 10-06-2021 02:23 PM
what i do is this.
once you have all installed put on the latch..the receiving part is fixed ,so loosen the 10mm head bolts on the lid and close it but not all the way just before the click, lift it a little and tighten those 2 bolts.This way you know it is aligned against the receiving female part latch..and of course lube it all.
make sure your rubber on each end of the lid are there,they serve as back pressure for the opening the lid..
I hope this helps
Ivan
kimlangley7 10-06-2021 05:11 PM
I used some silicone putty at the receiver portion [lower] of the latch. Spread it around so you can ascertain where the top plunger is mating with the lower portion. Make necessary adjustments for best fit.
kgl
Solamar 10-06-2021 05:22 PM
Best tip I've heard is to remove the grill first. That way if you get it stuck, locked, you can reach in and adjust
ian c2 10-06-2021 07:05 PM
Remove the grill .
Put masking tape over latch , and a little blob of nail-polish on spike .
Lower down slowly until you fell you’ve hit the masking tape .
Repeat until you are central .
proporsche 10-06-2021 11:57 PM
i do not think you have to remove the grill at all ..at least i have never had to in 38 years;-)working on these beasts...remove the upper piece adjust your lid so it is where is supposed to be,attach the upper male part and as i said above...
Ivan
sigchuck 10-07-2021 03:34 AM
Thanks, guys!
I think I’ve got it lined up correctly as it will close and latch, and when I pull the lever it will pop open. The issue I’m having (thats somewhat terrifying) is getting the lid open after it pops back up. It just doesn’t want to come out of the lower latch. I eventually got it open after putting a pair of vice grips on the door jamb pull, but any thoughts? Is it a fine adjustment issue for the upper latch? Front to back or depth of pin? Does it just need extra grease?
There are also adjustable depth rubber bumpers at either side - I had assumed these were just for setting body lines correctly but any interplay with lid opening?
Thanks!
proporsche 10-07-2021 05:47 AM
yes it is an adjustment on top. The 27mm nut you have to loosen it and the pin has a slat for screwdriver. But you also have to adjust the 2 rubber stops on each end, these will help the hood to pup up...
Ivan
proporsche 10-07-2021 06:46 AM
well..? if you do some search even here and have the hood aligned properly there will be no drama ;-) quite simple adjustments
Ivan
maybe i`ll do a video about the adjustments....
sigchuck 10-07-2021 08:17 AM
Thanks, Ivan - I would subscribe!
I think I'm thinking about this correctly, but the rubber stops should maybe be extended more (to provide more back pressure/spring) and the pin on the top latch should be recessed more/screwed in (so it fully clears when the latch is released)?
proporsche 10-07-2021 09:16 AM
ye something like that the rubber works like back press. the pin play with the adjustments 1st make it longer so you will see how it works..by now you have most likely everything centered so no worries about getting stuck.
Ivan
Just remember the bottom latch should be adjusted not to tight not too loose it works like this if the cable for some reason breaks it will open and release the upper pin...
B_El 10-09-2021 10:49 AM
Make sure there's some lithium grease on the plunger and the latch. That was the fix for me when dealing with the failure to fully release.
