Max Advance stock 3.2
Okay, I have been searching but have not found a definitive answer.
What is the max timing advance for a stock 3.2 and at what rpm? Running 93 octane. Also while I am at it does anyone have the ignition timing curve for a 3.2 in a simple map. The map that is in my manual is a three axis map.
Thank you in adavance.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 10-09-2021, 04:57 PM
The third map down may help:
https://www.911chips.com/ignition.htm
Old 10-09-2021, 07:15 PM
Thanks.
Old 10-10-2021, 07:44 AM
