Duplicate ignition key
Is it possible to have a duplicate ignition key made without having an original key? My key is so worn down that i can pull it out of the ignition while the car is running, don’t think there are enough distinct notches/ridges to copy.
Worked fine for me when I had a similar (but not as extreme) problem a few years ago |
Ok thanks. I’ll will soon find out if it works!!!
I understand you can still get replacement keys from Porsche using your VIN.
Walt 82SC 3.0 81SC 3.6 |
I’ll check Walt. Thanks
6 cylinder symphony
I bought my own key cutting machine. It has one cutting wheel. I love it. I've cut car keys, motorcycle keys, house keys. I had a similar issue with the key on my 84. Bought Porsche key blanks and have cut at least 2 "new" keys with my machine.
My machine is from Ilco. They aren't super expensive, and I think worth it. This is similar to my machine:
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife Last edited by Kidasters; 01-25-2021 at 03:58 PM.. |
Just seeing if you have your key code card. Should be a small credit card size piece of paper. Mine was with my service manual. If you do, you can send this to a few different websites and they can cut you a new key. Mine had 3 digits and that was apparently enough. New keys worked well.
cycling has-been
When I tore apart my 76 door handle, I discovered that the lock cylinder had a number of brass 'flags' in them.
The flags are numbered, and when viewed in sequence, translate to the key code. The flags are spring loaded, and if the key were to be withdrawn. the spring loaded flags would pop up or out. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 01-26-2021 at 08:47 AM.. |
My other ride is a C-130J
Easy to use and works great. . . My brother’s truck was having the same problem as you Jgurnari, so I cut him a new key and voila ! Problem solved. The problem was not the teeth wearing down but the key itself getting thin over time. I had to pay $10 to get a golf cart key copied last month. Wasn’t happy about that, considering key blanks are pretty cheap. If you are still having this problem, I would try duplicating your existing key, it may just do the trick.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
The key to my '79 SC is bent and I'm worried it will break soon, so I order a blank from Pelican. Had it cut at Ace hardware, sure looks exact but won't turn in the ignition switch. It won't unlock the door either, but WILL lock it! So it's got to be close... any tricks to get it to work? Wire brush it or something like that?
'59 356 Cabriolet '79 911 SC Targa |
Eng-o-neer
You have to find a "good" key cutter. I brought mine to a locksmith and the key wouldn't turn in the ignition. He recommended someone who was much better at cutting keys...
I wish he'd given me the recommendation before I spent $3 to ruin a $30 blank... |
Reiver
Ace hardware did one for me that works
De Oppresso Liber Strength and Honor 5th Legion |
| Tags |
| duplicate key , ignition , key |
