Or, you are only using 3 of the 4 channels and each coiling is getting half power spark..... |
I’m only using 3 channels.
The spark on the exhaust stroke encounters much less resistance than the power stroke so the power is not split 50/50. |
Ok. From what I have read, the wasted spark on the exhaust stroke takes about 12% to 25% of the energy required on the non-wasted spark on the compression stroke. It would seem that each plug is getting, at most, only 38% of the energy it would otherwise get if the plug had its own channel.
| All times are GMT -8. The time now is 11:16 AM. |
