Finally: Brembo upgrade from Rebel Racing.
The brake upgrade has arrived! I plan to change the front calipers first then upgrade the rear calipers early next year.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs Last edited by flat6pilot; 10-15-2021 at 08:26 AM.. |
You will likely have a huge brake imbalance between changing the fronts and the rears. This could lead to loss of control during aggressive braking; not a recommended situation. Better to do both at once.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Wow..lovely stuff!!
Ole Skool - wouldn't have it any other way |
They'll both effectively be done at once. The car isn't driven much in the winter months around here so "early next year" means the car is still sitting in the garage. No aggressive braking will be done until Spring track season starts again.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
