Gearing calculation
I have a question regarding gearing
- how to calculate the percentage difference in gearing be between these tire setups.
205/55-16 + 225/50-16
VS
205/50-15 + 225/50-15
Old 10-15-2021, 03:38 AM
Racer
winders's Avatar
https://www.gboxweb.com/gearchart.html
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-15-2021, 04:35 AM
Originally Posted by winders View Post
Thank you winders
Can you explain what "Aspect Ratio" in the spread sheet is?
Old 10-15-2021, 04:51 AM
Aspect ratio is the middle number in the description of the tire, i.e., "P345/25/19" The aspect ratio is "25" representing height over width. The higher the number, the taller the tire (or less sidewall, if you look at it that way). The tire manufacturer usually lists data on every tire they produce. Rollout or circumference will work, as will tire diameter, too. You need to know the actual tire circumference.
Old 10-15-2021, 04:58 AM
gearhead
VS
Only the rear tire matters when entering into the calculator.
Old 10-15-2021, 05:28 AM
Great, thanks a lot
Old 10-15-2021, 05:29 AM
Thanks a lot
Old 10-15-2021, 06:47 AM
Tire Rack may have the revs per mile for each tire. Easy to calculate all after that.
Sold: 1989 3.2 coupe, 112k miles
Old 10-15-2021, 06:48 AM
Bill Verburg's Avatar
VS
Using the manufacturer's advertised OD can give you an approximation of the effect on gearing, a more accurate assessment is given by starting w/ revs per mile
speed in mi/hr = (rp_minute*60/(rp_mile * the overall gearing))
overall gearing = cwp ratio * specific gear ratio
if you are only interested in the gearing but not the speed then imple division is all that is necessary
for say A052;
225/50 x16 OD is 23.9" and rpm is 869 giving an effective loaded diameter of 23.2"
225/50 x16 OD is 25.0" and rpm is 831 giving an effective loaded diameter of 24.3"
23.9/25 = .956 according to this the tire gear ratio is reduced by ~4.4% w/ the taller tire
869/831 = 1.04573 this gives a truer picture the gear ratio is reduced by ~4.6% w/ the taller tire
Bill Verburg
Old 10-15-2021, 10:41 AM
