-   -   when to replace motor mounts? (http://forums.pelicanparts.com/porsche-911-technical-forum/110460-when-replace-motor-mounts.html)
einreb 05-12-2003 07:25 PM
Ok, I'm installing some bilstien sports on the rear of my '88 911 and I notice that when I jack up the car via the engine (with a recently purchased AC Hydraulics jack from p.p.) that there is some 'play'. I.E. the engine jacks up a bit prior to lifting the car.
Question... how much 'play' is normal? How tough is it to replace them on my car? Easy to do the fronts too? I read something about the mounts with the G50 being different.
I searched... but didn't see a 'when to replace' thread (feel free to point it out).
Thanks!
Bernie
buttjoint 05-12-2003 07:31 PM
The rubber is usually cracked when thir gone.
einreb 05-12-2003 07:34 PM
ok, the top side isnt cracked... i can feel the bottom side... doesn't seem cracked. Should there be 'play' as the engine is lifted? can something be tightened? I see the one big bolt and two small bolts to either side.
