-   -   Fog lights w/ high beam off/on issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1104812-fog-lights-w-high-beam-off-issue.html)
LucaScali 10-19-2021 04:30 PM
In my car the fog lights should switch off with the high beam and switch back on when it's turned off. It sometimes works this way, but often the fog lights will turn off with the high beam, but wont come back on when the high beam is switched off. When this happens, you have to turn off the fogs and turn them back on to get them working. Otherwise the turn signal switch operates perfectly. What could be the problem? Thanks very much.
Mark Salvetti 10-19-2021 05:27 PM
Sounds like the relay may not be functioning properly. I would try swapping it with another black relay and see if that fixes the problem.
Mark
spedrcr 10-20-2021 08:43 AM
Swapping relays is a great start and easy to do. Secondarily, check for potential grounding issues specifically with the stalk switch.
LucaScali 10-20-2021 01:07 PM
Thanks very much, guys.
spoke 10-23-2021 05:06 AM
Are you sure the high beams turn off when the stalk is pulled? It seems a common wear item is the high beam contacts in the turn stalk. I had an issue where the high beams would stay on or even come on if I hit the turnsignal stalk. There's a set of contact in the turnsignal stalk that needed adjustment.
LucaScali 10-29-2021 09:16 AM
It was the relay. Thanks!
