-   -   901 Transaxle CV Output Flange Dilimma (http://forums.pelicanparts.com/porsche-911-technical-forum/1104852-901-transaxle-cv-output-flange-dilimma.html)
ironhorse 10-20-2021 01:19 PM
I need to remove the CV style output flanges on my transaxle (901.301.101.02), but having difficulty determining how to perform the task.
Normally, I'd expect to see small circular plugs covering the bolts holding the flanges to the shaft, or just the bolt heads ... but this one has me stumped.
On each side, there's a circlip holding some sort of aluminum(?) 'plate' with what first appeared to have a small bolt protruding from it, but neither a 11mm or 12mm would fit the head - then, upon closer examination, realized that it's not a hex-head bolt at all :confused:
I removed the circlips, but was unable to grasp the protrusions on the 'plates' with enough leverage to remove them. I don't want to damage anything.
Anybody else experienced this? How do I get these 'plates' out? - Is there a special puller for these?
http://forums.pelicanparts.com/uploa...1634760099.jpg
http://forums.pelicanparts.com/uploa...1634760218.jpg
http://forums.pelicanparts.com/uploa...1634760462.jpg
http://forums.pelicanparts.com/uploa...1634760007.jpg
http://forums.pelicanparts.com/uploa...1634760486.jpg
faapgar 10-20-2021 01:54 PM
the plug
You grab it with an inverse pair of dykes type plier and just rock it out.The flange bolt is underneath.Not to tough to remove.These are on pre-68 trans.
john walker's workshop 10-20-2021 02:22 PM
Looks like someone used sealer, which makes it harder.
ironhorse 10-20-2021 04:46 PM
You weren't kidding. What a P.I.T.A. they were to get out. The transaxle was rebuilt 40 years ago and sat on a shelf in my garage ever since.
Heating with MAP gas didn't help - had to drill and pry them boogers out. There were o-rings encompassing them and possibly some sort of sealer on them too.
http://forums.pelicanparts.com/uploa...1634773321.jpg
http://forums.pelicanparts.com/uploa...1634773361.jpg
Long story short - they're out and my mess all cleaned up, so I can move on to the next step ... pulling the flanges to install new seals.
http://forums.pelicanparts.com/uploa...1634773428.jpg
Thanks for the help ... ;)
Matt Monson 10-20-2021 05:39 PM
What a pain. I might have a couple of those caps if you need replacements.
47silver 10-20-2021 08:31 PM
are the threads through the flange?
if so would you have ebeen able to screw some bolts through the other side and put a wrench of flat plate to protect the case and slowly press them out?
ironhorse 10-20-2021 11:49 PM
Shoot me a private message Matt, and let me know what you'd want for them - obviously I won't be reusing the old ones ... LOL
ironhorse 10-20-2021 11:56 PM
In hindsight, I probably could have drilled and tapped the holes and threaded a couple of bolts in the plates to press them out. It's all water under the bridge now, but I'll keep that in mind should I ever encounter the situation again ;)
Matt Monson 10-21-2021 04:41 AM
I’ll check the old parts stash today and ping you if I have some. I’ll just give them to you for the cost of shipping.
ironhorse 10-28-2021 09:10 AM
Cool. Thanks Matt.
john walker's workshop 10-28-2021 09:38 AM
I have a couple if Matt doesn't.
