23mm Front sway bushings source for RUF sways
Does anyone know where I could acquire some of these bushings? I am in the process of installing some RUF sways and need some bushings that will fit. These are the type that fit in the tabs on the A-arms. Looking for the rubber bushings not poly.
The ones that came with the sways are too small. Porsche part number 911.343.881.00 These are almost the same size as the ones that came off the car with 20mm front sways. I was thinking of hacking them but not sure what would cut the rubber cleanly in a circular fashion. Some material needs to be removed. -Jeff nolift911@hotmail.com |
anyone...?
Try Weissach Performance in Vancouver, B.C. Great people and they are the only authorized Ruf dealer in all of North America. 604 738 3911 or www.weissach.com
Cheers, Jeff |
If it was me, I would just go at them with a round file.
It shouldn't take much, and worst case you need to buy new ones anyway. The stock 86-89 version may work, it is 22mm. Wayne has them for $6 here. Tom |
| All times are GMT -8. The time now is 10:18 AM. |
