-   -   Installing MSD, wiring question? (http://forums.pelicanparts.com/porsche-911-technical-forum/110508-installing-msd-wiring-question.html)
power 05-13-2003 07:53 AM
Installing MSD Ignition (tested already and worked great, my tach even worked!). I am fabricating a mounting bracket for the unit to go in the place vacated by CDI unit (Moving other electrical components around to make room). I was wondering if other people that mounted the unit in same position can tell me how they routed the hot wiring to the starter, I was working from Waynes book "101 projects".
lendaddy 05-13-2003 08:15 AM
I did not run the hot from the starter. I used the unused hot I had at the three fuse connectiion right there. Never had any issues. Look at the amp draw of the unit, not very high if I recall.
ruf-porsche 05-13-2003 08:27 AM
If you run the hot wire from the starter the unit will always be on. Wouldn't it be better to run a wire from a fuse that is switched?
jtkkz 05-13-2003 10:13 AM
I installed a MSD on my 1973 and had my brother fabricate a bracket for me.
pic attached.
http://forums.pelicanparts.com/uploads/msdbracket.jpg
