78 911sc Ignition switch issues
Hello all
My original key will no longer start my car. The key does not turn. The wheel is locked as well.
I am searching topics and reading everything I find but nothing explains what the little white 2 pin plug is for that connects down on the steering lock housing beside the ignition switch
Looks like I will be removing the switch to either replace it or try to get a key made.
Any input is appreciated
Old 10-29-2021, 08:16 AM
I finally found the answer it activates the buzzer that tells you the key is in the switch when you open the door
Old 10-29-2021, 08:40 AM
If the wheel is locked under any tension, relieving the tension will often allow the key to turn.
Sent from my Nokia 7.1 using Tapatalk
Old 10-29-2021, 11:26 AM
Spray some tri flow in lock then move wheel back and forth while turning key.
Old 10-30-2021, 05:38 AM
