-   -   Problem seating springplate rubber (http://forums.pelicanparts.com/porsche-911-technical-forum/1105815-problem-seating-springplate-rubber.html)
D@vid 11-03-2021 03:31 AM
Hi guys,
Ik need some help from the "allmighty knowledgebase"
I've recently replaced my springplates (with new rubbers) but somehow the rubber keeps bulging from the rear torsion plate covers.
Is this normal and will the rubber seat when driving or am I doing something wrong?
http://forums.pelicanparts.com/uploa...1635935362.JPG
Kind regards,
Classic 911 11-03-2021 04:54 AM
Following.
Tommy Z 11-03-2021 10:50 AM
I just finished this awesome video on Youtube about this procedure. If you forward to the end you can see his finished product and as far as I can tell there is no bushing visible around the torsion bar cover. Hope this helps.
https://www.youtube.com/watch?v=MaqwQRMpndI&list=PLkWFofpgz2Og6nqijrJAFz7M B_vVCU9Vp&index=2
D@vid 11-03-2021 11:29 AM
Thanks, excellent video.
David Inc. 11-03-2021 11:56 AM
For sure not normal. What was the rubber and how did you prepare the plates?
chrismorse 11-03-2021 12:36 PM
Manufacturer and lube >>
Hi Dave,
A couple of questions, Who made the bushings?? and what did you use to assemble the bushings to the chassis/cover??
chris
D@vid 11-03-2021 01:36 PM
Springplates and rubbers are from dansk I believe. I put the covers on with lots of soap en tightened the bolts a few turns at a time each
D@vid 11-03-2021 01:39 PM
Still have the original (non ajustable) spring plates. Maybe I should give them a try
john walker's workshop 11-03-2021 03:24 PM
Did you super glue the bushings to the spring plate tubes first?
D@vid 11-04-2021 12:55 AM
Hi John,
The rubbers came pre-attached
http://forums.pelicanparts.com/uploa...1636012510.jpg
88911coupe 11-04-2021 07:20 AM
That does look odd. I did this job years ago and searched far and wide to find a glue that actually worked, found some esoteric 3M adhesive that was supposed to work on steel and rubber under extreme conditions. It didn't, the first time I drove it in really cold weather the adhesion broke and I got low squeak over bigger bumps. I've gotten to where I ignore it...maybe I should have just used super glue. Since yours came pre attached maybe they will stick.
D@vid 11-04-2021 09:02 AM
I’ve tried to to tighten the bolts several times and never noticed loose rubbers
john walker's workshop 11-04-2021 09:17 AM
Are the outer retainers original or aftermarket?
D@vid 11-04-2021 09:39 AM
All aftermarket john
john walker's workshop 11-04-2021 10:17 AM
Try your original for the hell of it.
D@vid 11-04-2021 11:47 AM
I'll do that. I will keep you posted.
thank you all for your input.
Tom F2 11-04-2021 11:55 AM
Are spacers needed between the threaded mounting bosses and the retainers? It's been a while, for me, but I recall that I needed 4-5 mm spacers to make the adjustables fit an early (this is a 1973?) car. Cylinder head washers did the trick, as I recall. All from distant memory, so don't pile on if I got wrong. All this to compensate for the greater thickness of the adjustable spring plates, compared with the originals.
Tom F2 11-04-2021 11:56 AM
You also want longer bolts and the thicker spacer for the lower, rear mounting bolt.
75 911s 11-04-2021 01:22 PM
^ This. If it's the car from your "garage" link it's a 73. Did you put the spacer back in the rear bottom corner? The cover should be perpendicular to the ground like a T. If there's a weird angle to it, you may have left out the early car spacer.
It's just a single spacer. It's not one on every corner. You do use additional spacers if you use polybronze bushings, but not the rubber bushes.
http://forums.pelicanparts.com/uploa...1636057621.jpg
D@vid 11-04-2021 02:26 PM
Thanks but the spacers are correctly installed
