lateapex911's Avatar
Engine mount refinishing?
So, in my slow partial redo of my engine, I'm repainting (Cerakote) all the parts I can "While I'm there".
The engine strap and some other bits like the pulleys I think might go to Shawn at Tru-6.
But the engine mounts, well, they look like engine mounts look after they've been driven hard and put away wet, so to speak, for 30 years...kinda kuck.
I was thinking of getting them plated...buuuut, they're bonded with rubber, so that's a non starter, I'd think.
Cerakote needs soaking in acetone and baking and surgical cleanliness....the rubber isn't going to allow that.
So what to do?
What finish and color am I shooting for anyway? (Stock would be the goal)
I'll send the big washer and bolts to Shawn.
I know, SOMEbody here will suggest just getting a set of Wevos!
Thoughts?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 11-06-2021, 12:01 AM
Replace them they’re no good anyway if they’re original.
Old 11-06-2021, 05:08 AM
Shaun @ Tru6's Avatar
Jake, definitely replace the mounts. There are 2 different versions, 91137504300 and 07 for cabriolets. Hopefully someone can confirm but I think the cab mounts use a stiffer rubber.
There are a range of mfg's for these and even thought Porsche quality is lacking these days, I'd get Porsche or German made at least.
Tru6 Restoration & Design
Old 11-06-2021, 05:40 AM
H-viken's Avatar
I believe the cabriolet mounts are a bit stiffer as well
Scrap your worn out mounts and replace them
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 11-06-2021, 06:25 AM
OK, it's universal!
One more cardboard box to recycle in my future!
Shaun, I guess I'll shoot you an email regarding the plating aspect, or is there a better way?
Thanks all!
Old 11-06-2021, 03:06 PM
