Fuel pump
Hi all.I'm looking to buy new pump for my 79 sc but can't seem to find one with 10 mm outlet.my part number is bosch 0580254957
Old 12-12-2021, 01:12 PM
BoxsterGT's Avatar
Porsche Crest
Just about everything is 12mm now. You can swap your original 10mm check valve to the new pump...
Or, I can send you a E85 Rated Front Feed repair hose with M12 Banjo that will fit a new pump.
Our host now has a replacement Bosch pump (12mm) that is very reasonable in cost (about $125 +/-).
Porsche has discontinued the 10mm Tunnel lines, so if you ever need a new one it will be 12mm.
Len
Old 12-14-2021, 01:55 PM
