-   -   Car out of alignment (http://forums.pelicanparts.com/porsche-911-technical-forum/1106227-car-out-alignment.html)
Travisrt1985 11-08-2021 03:44 PM
I just finished installing my sport 1 restoration suspension package from elephant racing and I cannot seem to get my car aligned properly. Does anyone have experience with alignments ? I need to know if my car needs another part. I’ve attached my recent alignment sheet and the parts I put on. It’s a 88 carrera .
http://forums.pelicanparts.com/uploa...1636414982.png
http://forums.pelicanparts.com/uploa...1636414982.jpg
Travisrt1985 11-08-2021 03:54 PM
http://forums.pelicanparts.com/uploa...1636415679.jpg
thetorch 11-08-2021 04:08 PM
Are you using stock camber plates?
I would ask Chuck at Elephant. He is very helpful.
dannobee 11-08-2021 05:02 PM
How low is it? Lowering will increase caster and decrease camber.
rumlyne 11-08-2021 05:07 PM
lowering mine sure didn't decrease my camber
Tyson Schmidt 11-08-2021 05:24 PM
Those specs are for 964, not an 88 Carrera
Your caster is what it should be. And your camber is fine at those settings.
Marc Bixen 11-08-2021 06:13 PM
Another shop that doesn't know what they're working on. As Tyson said, wrong specs. I had a tire shop that constantly was getting tire pressures wrong on g body and earlier cars, A VERY well known tire shop in Santa Monica, Ca. I even gave them a Porsche tire pressure guide. They continued to get it wrong, so I went over there. They showed me their industry tire pressure guide, ....starting 1991. Such incompetence!
Travisrt1985 11-08-2021 06:15 PM
So it’s a simple mistake of the shop using the wrong alignment specs?
Travisrt1985 11-08-2021 06:18 PM
Un freaking believable. They ended up keeping the car for an extended period of time over this issue as they made it seem like it was in need of more parts.
wrxnofx 11-09-2021 07:34 AM
Go elsewhere. I took my '87 to a shop for an alignment on a recommendation. I sat there for 3 hours. Finally, they told me they couldn't dial it in, that there was something wrong with the car. I looked at the strut towers - they had never even loosened them.
I went to another place, and he had it dialed in in 10 mins.
Marc Bixen 11-09-2021 10:30 AM
wrxnofx http://forums.pelicanparts.com/support/smileys/wat3.gif
that sounds familliar too. That same shop in Santa Monica called me one day, their "expert" 20+ years aigning 911's, told me the camber was out of spec on a car he was aligning, I said "yea, so, you can't get enough adjustment?" He says, "911's don't have camber adjustment in the front. It's either in spec, or the car must be bent." OMG, I drove over there, showed him the procedure, then advised my clients to never go there again.
Walt Fricke 11-09-2021 08:45 PM
Marc - really amazing. We here all know from reading that the first 911s were, indeed, designed without alignment adjustment, but Porsche very quickly realized what a mistake that was and provided adjustment. That was in the 1960s. Yet that is what that alignment guy thought?
Some things you just couldn't make up if you tried.
wrxnofx 11-10-2021 07:15 AM
I am the 5th or so owner of my 911. When I got it, the black tar stuff that covers the adjustment plates at the top of the strut towers was untouched. This means that for over 30 years either the car had never been aligned or it had never been aligned correctly. I chipped all that garbage off, needless to say...
wildcat077 11-10-2021 09:52 AM
I would purchase front camber plates from Chuck and take your car elsewhere.It is difficult to get matching front camber numbers on a 30 year old car but adjustable camber plates will make it easier for a shop that has even basic knowledge ...
When i bought my 89 911 some 12 years ago , i couldn't get anything more than -1.2 front camber on both sides when i started doing DE's with PCA, anyhow after lots of $$$ to Tarret and ER, etc ... spent upgrading and replacing parts i would say that my car is dialed in very well !
Find a good shop , install adjustable camber plates and with all the new parts you put into your car's suspension , have it corner balanced as well when you go for a real alignment.You won't recognize your car anymore !!!
