Hooking up a remote start switch without getting under the car
Picked up a trigger-style remote start switch so I can do some diagnostic work without having a helper up front on the ignition switch and I need access to hot 12V and the starter solenoid. Can I get to the latter circuit without getting under the car? And what’s the easiest 12V in the engine compartment?
12V a the top fuse. Peel back the covering on the 14 pin plug loom and stab a fat pin theough the big yellow wire for solenoid activation.
Thanks, John. top fuse? On panel in left rear of compartment?
'80 SC Targa Avondale, Chicago, IL |
Yup.
