-   -   Dumb Question: Windows come up wet. (http://forums.pelicanparts.com/porsche-911-technical-forum/1106483-dumb-question-windows-come-up-wet.html)
jalvani 11-11-2021 09:55 AM
On my '88, the windows operate fine but if I'm using the car within a few days of it having gotten wet, the windows will come back up just smeared with water. I live in the rainy PNW so this is often the case.
I have to take the door panels off for some unrelated work, figured I'd see if I could address this while I'm in there, just don't know where to start. Any suggestions?
AlistairWallace 11-11-2021 10:16 AM
I've noticed this too. From what I was able to determine the rubber that leans on the window has something that appears to be felt on the inside, which I think absorbs water.
I noticed that after washing it will smear the window for up to a day after. Never found a solution to it, so curious what others say
jalvani 11-11-2021 10:29 AM
Nice to know it's not just me.
bahman 11-11-2021 05:38 PM
Maybe the rubber strip which lays on the glass has lost its flexibility and does not wipe the glass as it comes up - sort of like dry-rotted windshield wipers.
Replacing that rubber piece is very tedious. There are a few threads on this site addressing it. May be worth your while to review them before tackling it.
bahman 11-11-2021 05:40 PM
PS,
My suggestion above is based on the earlier 911 models (up ton1978.) May not fully apply to yours.
jalvani 11-11-2021 08:03 PM
@bashman That’s what I was thinking, thanks. Believe it’s called the “channel strip” or something similar.
DaytonaCoupe66 11-12-2021 04:09 AM
Also check your drains at the bottom of the door seam for obstructions that may be preventing moisture from escaping.
911 Rod 11-12-2021 12:45 PM
Your car is how old?
Replace the felt strip.
