47silver's Avatar
oil screen nuts on engine case verdict
I have read many posts on what type of nut to use on the oil screen cover on the engine case. 2.7L enginer.
Some say use hex nuts with flat washers and lock washers, some say use flat washers and nylocks.
The pet shows hex nuts, flat washers and nut washers.
So which should I use?
Nylocks nuts with flat washers?
Regularhex nuts with flat washers and lock washers?
I am leaning towards regular nuts etc as that what was on the original so there must be a reason for that rather than nylocks. But would use nylocks if that is a superior method
thanks
1975 911S Targa
Silver Anniversary Edition
Old 11-10-2021, 05:43 PM
MichaelSJackson's Avatar
Nylocs are only rated to 250 degrees?
Old 11-10-2021, 07:03 PM
Harpo's Avatar
I thought they made hi temp versions of the nylon lock nuts
I stand corrected, neither Belmetric or McMaster carr have anything above 245F
Old 11-11-2021, 05:49 AM
47silver's Avatar
So hex nuts not nylock thanks
1975 911S Targa
Old 11-11-2021, 07:11 AM
Wildman Emeritus
Timely thread. Oil change screen clean and storage time. Time to visit Ace for some nuts and washers. I had considered Nyloks but will go with flat.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 11-15-2021, 07:51 AM
47silver's Avatar
Make sure your plate is flat. I used a couple of different flat files to get it flat. You will see the high spots immediately. I used a straight edge ruler to make sure it was flat after filing.
1975 911S Targa
Old 11-15-2021, 11:38 AM
And don’t overtighten the nuts when replacing as this distorts the cover leading to leaks/seeps/weeps
Old 11-16-2021, 04:16 AM
Banned
The Acorn nuts off of a early VW sump plate worked well for me
Old 11-16-2021, 05:34 AM
