-   -   Can I drop a 930 transmission in a 3.6 SC? (http://forums.pelicanparts.com/porsche-911-technical-forum/110653-can-i-drop-930-transmission-3-6-sc.html)
Moses 05-14-2003 09:24 AM
I'm not sure yet what damage, if any, I've done to my 915.
If I tore up the tranny, is a 930 a reasonable option? I really do want taller gears for easier street driving. From what I've read, the G50 conversion is very involved ($$$).
Maybe a 930 will give me a durable tranny with less cost. Anybody done this?
Sean Hamilton 05-14-2003 09:33 AM
Moses
Oh oh! :eek:
So it wasn't just the CV's then?
Moses 05-14-2003 09:34 AM
Re: Moses
Originally posted by Sean Hamilton
Oh oh! :eek:
Haven't heard yet. Lately I just assume the worst.
thethrill 05-14-2003 09:58 AM
An early 76-77 turbo trans (short bellhousing) is basically a bolt in to an SC. Short bellhousing models are tough to find! Long bellhousing versions are readily available, however you would need to have a new rear panel/motor mounts installed.
To take advantage of the trans your would want to shorten 3rd and 4th gear (and possibly 2nd).
Turbo trans are bullet proof. I have 100K on mine with a 400+ hp turbo, no problems! Also most turbo trans come with LSD's.
ruf-porsche 05-14-2003 11:38 AM
Just don't try to shift into 5th gear
Embs 05-14-2003 12:11 PM
Moses,
I asked this exact same question a while back. I believe both John Walker and Jack (OMRBCHWDP) Olsen said that the gearing wouldn't match the 3.6 power curve.
However, since then I have driven a 930 with a NA 3.6 Varioram with the original 4 speed and I really liked it. It felt much better that the 915. The guy did the transplant work himself. I am trying to get him to post some pics to the BBS. His car is really sweet.
He was a former BOOST-O-HOLIC.
IMHO, the 915's stock 1st. gear is a waste when mated to the 3.6 Vram. I would like a much taller 1st in a 915. It would make the car much more fun for me. I would like to be able to get to 60 in 1'st gear.
Embs 05-14-2003 12:13 PM
The other problem is finding a good 930 tranny. There just doesn't seem to be many around. Of course I think there is a fresh one on my garage floor in the corner :D
beepbeep 05-14-2003 01:10 PM
pre -78 930 boxes bolt straight in. post -77 boxes have longer clutch housing (to accomodate rubber-damped clutch) so they have to get shortened as 930 back end is actually longer than SC (so engine sits further back)!!
Otherwise than that...930 boxes are impossible to break, even with 935 engine... 3.6 with it's spinky torque cannot do anything to its gears. Synchros get worn with time and should be replaced in time.
We bought clean and rebuilt long 930 box for 1200$... short ones are somewhat more expensive as they aren't so common. Apart from the clutch housing, they are the same...
1fastredsc 05-14-2003 02:24 PM
For the kind of price you'd pay for a 930 trans, or at least a good rebuilt one, why not just rebuild the 915 and put in gears that are accustomed to your standards?
ChrisBennet 05-14-2003 03:05 PM
The 915 really isn't built to handle the torque of a 3.6 though I guess street driving might not tax one that much.
-Chris
89911 05-14-2003 03:29 PM
Do you really wany to take your fantastic 993 engine that was meant to run with 6 speeds and cram it into just 4 gears??? You can beef up a 915 to handle it but a G50 is the way to go.
beepbeep 05-14-2003 04:43 PM
915 box sucks, rebuilded or not. It's the sad truth.
ChrisBennet 05-14-2003 11:34 PM
Amen, bro.
-Chris
rdane 01-18-2005 12:39 AM
Embs...did you put the 930 box in your 3,6 yet?
look 171 01-18-2005 02:45 AM
Hey the 930 box sucks too, but boom proof. The shifting into 2nd is just have to be done ever so slow, or else click click and slight grind then into second. Who does 60mph in first? Can you see yourself slamming the gear lever into 2nd at 6800rpm on boost. It's a horrable feeling. Chaning the ring and pinion may work ok and cheaper too. Stock 2nd and 3rd was my favorite gear. Now it's just 3rd.
Jeff
look 171 01-18-2005 02:47 AM
I mean bomb proof, sorry
real550A 01-18-2005 04:25 AM
"915 box sucks, rebuilded or not. It's the sad truth."
All those threads on "which is better, G-50 or 915", are being summarized here in one short sentence.
I have one of each, and prefer the G-50.
PorscheGuy79 01-18-2005 06:20 AM
On a side note, the new Z06 does which directly relates to its very quick not to sixty time of 3.9.
lendaddy 01-18-2005 06:41 AM
After my 930 box was rebuilt by Gary Fairbanks, the 1st to 2nd shift was great. Before the rebuild it was a slow process to "get" second.
beepbeep 01-18-2005 08:21 AM
Jeff
930 box uses same synchro design as 915, so shift-feel and wear-tear are apporoximately the same. But it's built much stronger and will stand any naturally aspirated Porsche engine 'till the cows come home. No chance in hell that the housing will twist and gears fail.
If shifted frequently, it's synchros will get worn just like in any other (porsche synchromesh) transmission. In Europe, itäs usually 3:rd gear (due to highway overtaking 2:nd to 3:rd on-boost syndrome) that is toast. If driven mostly in town with enforced 55mph limit, it might be 2:nd that's worn.
IMHO it's better transmission than 915 if you don't need to play red-light "who's faster" game...
