Remove the black paint from trim??
any tips for removing the paint from the frames on the doors etc?
im in europe and there is no good paintstrippers i can find, sanding the only way? i want to polish my frames on my backdate |
i used an old paint stripper can and it did the trick. Check your local auto painter shop to see what they use. Newer paint stripper are less stronger due to environmental requirements. Good Luck.
Jose |
Make sure whatever you want to remove is actually paint, rather than anodizing.
'80 SC Targa Avondale, Chicago, IL |
Wildman Emeritus
This!!
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
I didn't feel like grinding a full weekend.
dropped the parts at a coating shop in the morning. They dipped them in a basin of secred potion. fetched them after work all stripped clean and smooth.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Full Send Society
Make your own stripper:
Methyl Chloride Carbopol Ethomeen C25 Mix the carbopol (syrup) with the ethomeen (powder) u til it’s a paste without lumps, then add a bit of distilled water to thin it out, then add the methyl chloride. You can add acetone or N-Methyl-2-pyrrolidone too if you have it or want a more complex chemical solution. It will form a fell that can be brushed on to the window frames and it will melt the paint right off. Methyl chloride and N-Methyl-2-pyrrolidone are toxic so work outdoors with PPE
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Dashman0
Black trim
The best method is to find a good anodizing shop. They can strip your trim work and they can anodize them in chrome. This way you won't have to keep buffing and polishing them to keep them bright.
