85 911 3.2l hard starting when cold
hi. i have a 85 911 with a 3.2l that runs perfect all summer, as soon as it starts to get cold it doesnt want to run. it chugs at maybe 300 rpm until i give it some gas then it will climb but it will go back to chugging if i take the gas off. if i keep the revs up it will drive but if the vehicle is shut off it does the same thing. if the car is kept in a heated garage its fine even when you go outside in the cold. does any one have any suggestions as it is driving me crazy. ive replaced the plugs, cap, rotor and wires. so im pretty sure it is a fuel problem. any help would be great. thanks
Old 10-11-2010, 08:25 PM
I've heard that the majority of engine wear occurs when you are starting the car because the oil is not yet heated and flowing steadily to lubricate engine. And this is especially the case in the cold when the oil takes a longer time to heat before it can start to lubricate the engine. I realize This may not answer your question but I'm no pro so this is my guess.
'80 911 sc
'96 Range Rover
Old 10-11-2010, 08:31 PM
hi. i dont think it is a oil problem as it doesnt go away even after the car is warm. im pretty sure it is some kind of a sensor problem with the fuel system but im not sure. thanks, for the reply.
Old 10-11-2010, 08:51 PM
Grappler
Rodsrsr's Avatar
Check or replace the cylinder head temp sensor. It is located in the back of the engine, drivers side, under the car where the gearbox mates to the engine.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 10-11-2010, 09:00 PM
E Sully's Avatar
Make sure your microswitch on the throttle body and your Idle Control Valve are working. Check your o2 sensor. Do you have an old single wire head temp sensor? The 2 wire is better. Is your fuel pressure good, clean fuel filter? How is your AFM?
Ed
1973.5 T
Old 10-12-2010, 02:22 PM
Also check to se that the Idle Control Valve is working. My 84 Targa does the same thing, so one of these days I will get around to replacing it. Just have someone turn the key to just before start and put your hand on it to see if you can feel any vibration.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 10-13-2010, 07:14 AM
steely's Avatar
mercdragon33 - any update on this, buddy?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-02-2010, 05:37 PM
Igor64
Have you found any problem with this ?
Old 12-12-2021, 02:10 AM
proporsche's Avatar
mary in france why don`t you go to type911.org in France Porsche forum?
Also look at the date of the last post, it was almost 12 years ago....
what problem do you have?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-12-2021, 02:35 AM
