EPS and XPS have been my friend for about 40 years. We have cut it with a hot knife, sanded it and created a number of mules to form it, much like you did here.
http://forums.pelicanparts.com/uploa...1649000912.jpg Well done !!! My favorite way to get what I want out of EPS is using a 5 axis machine owned by a business associate. |
Many years ago I watched my father and some buddies build a full scale foam sailplane (motor less glider) with 15m wingspan. They were making molds of it for production in carbon fiber. They were a bunch of Swiss, German and Polish guys who could barely communicate verbally but worked together with pure harmony. |
Julian,
This thread really brings me a lot of joy. It's incredible watching someone with such taste and talent follow their heart without constraints. Also, your movie quotes are perfect. I lol'd pretty hard at, "Mark it ten, dude." |
Sunday I couldn't help myself.
I ran to work while my wife and kids napped and grabbed some leftover perforated black vinyl I had from another project and decided to try and make a thing. Some of you like putting big speed holes into your metal... I like putting tiny speed holes into my fabric. Get used to this, there's a lot more comin' http://forums.pelicanparts.com/uploa...1649097473.jpg http://forums.pelicanparts.com/uploa...1649097473.jpg http://forums.pelicanparts.com/uploa...1649097473.jpg |
Damn, that's very cool!
Day 23
Going forward I'm going to update the thread on Saturdays when I get home from working on the car. Back to the dash. With my table saw back in action I was able to finish cutting and shaping the MFD filler pieces for above the aluminum trim. The shape of the glove box piece is really complex and the ability to shape the material accurately was a major reason for choosing MDF and it did not disappoint. Anyhow, with all of the pieces complete it was time for a dry fitting. I drilled several holes through each aluminum piece and countersunk them to receive a machine screw. I had to drill into the dash metal as well and happily, my alignment was spot on. The aluminum dash pieces will be bolted to the car and the fiberglass filler panels will be spot adhered to the aluminum. This way they can be pried off if ever needed… The filler pieces above the trim will be adhered to the car just like the factory ones which weren’t ever meant to be removable. I chose to wrap the top filler pieces in black vinyl and after acquiring nearly 20 samples I settled on the least offensive one. None of them, including the so-called Porsche patterns were a perfect match and the biggest issues were the color and sheen. Luckily this is a dark area that will be overshadowed by the other parts. Ha, see what I did there… (work with me guys, I was up at 4:30am again) I mentioned earlier that I eschewed the HVAC bezel because I thought it too busy and well, predictable. While I respect others’ feelings about basket weave, it’s not for me. With respect to the lexicon of design in the 911, it’s an outlier. It’s a pattern that doesn’t exist elsewhere and doesn’t reference anything else. To that end, I don’t find it special enough to break a rule of design. On the early cars with a wood dash, it referenced the wood steering wheel and felt really special; real organic wood in a car. I considered a veneer- I have rosewood, ebony, walnut, and a bunch of others but they didn’t feel right, maybe for a 356 or 901 but not this car. So, sitting in the car I looked elsewhere for cues and I found them above and below me. The headliner and the seats in my car are both perforated, one vinyl and white, the other leather and camel colored. Though the pattern, color and materials are different they point to each other and in that, there’s a harmony of design. After requesting and receiving samples of perforated vinyl from 9 different vendors all claiming to have the correct pattern (only one did, World Upholstery) I was able to get some old headliner from another pelican (thanks 911Group!) and began finishing the glass inserts. So now that I’ve written a thousand words, here are few thousand more…. http://forums.pelicanparts.com/uploa...1649515327.jpg I'm digging the perforated black vinyl accents and given that I have yards of it... well... http://forums.pelicanparts.com/uploa...1649515327.jpg Dry fitting before vinyl and everything looks good http://forums.pelicanparts.com/uploa...1649515327.jpg Dry fitting after vinyl and everything still looks good! http://forums.pelicanparts.com/uploa...1649515327.jpg From a distance, or an acute angle it looks like plain black vinyl, but up close or an obtuse angle the perforation reveals itself. http://forums.pelicanparts.com/uploa...1649515327.jpg With the HVAC face covered and the bezel, radio, ashtray and upper knobs deleted, the dash is minimal and clean. http://forums.pelicanparts.com/uploa...1649515327.jpg The switches and dials are a nod to the great HiFi systems of the 60s and 70s http://forums.pelicanparts.com/uploa...1649515327.jpg The simple appearance of the HVAC controls betrays its mind bending complexity...ha! the knobs still need a polish but that can wait until my hands are clean. http://forums.pelicanparts.com/uploa...1649515327.jpg Yes, I have plans for the ignition cover... now, where's that lathe...? http://forums.pelicanparts.com/uploa...1649515327.jpg Up close, the color peeking through the hols reveals itself as gold... in the right light they shimmer a bit. A nod to the brass work that will appear around the car. And there it is. Still just a dry fit so alignment isn’t perfect but it will be. A big change from the mid-year dash I previously had which was a mishmash of mayhem, and a subtle difference from the predicable backdate dash. I think it fits in with the car well, is understated, clean and most importantly, makes sense. Oh, and nobody in the world has it ;) |
Following……very nice clean and unique result on the dash.
I’ll be back to review this thread when I embark on my CR A/C instal into my new project. Cheers, Johan |
Dieter Rams?
Hi, Julian, nice work I like the original take on your dash / knee bolster. When I saw your switches and HVAC sliders, reminded me of this.
http://forums.pelicanparts.com/uploa...1649635146.jpg |
Tom, as a student of and professional in the arts, the reference to Braun and Rams is a compliment of the highest order!
Day 24
With the combination of the double holiday weekend (Passover and Easter) and my daughter’s 6th birthday party my time with the car was limited to say the least. A grand total of 2.5 hours was hardly enough time to make major progress. That said, I made the most of it. I laid down another coat of primer and gave it a good old sand up to 400 and removed all of the formidable scratches. http://forums.pelicanparts.com/uploa...1650290045.jpg http://forums.pelicanparts.com/uploa...1650290045.jpg While doing that I decided that my old oil lines which had been painted brown, white and dirt needed some attention if only to see what was under the accumulation. A brass wire wheel on the angle grinder and some 400 sandpaper has them looking vintage new. Sure, they’re not perfect but nothing on this car is and the wear and tear add to their…character… http://forums.pelicanparts.com/uploa...1650290045.jpg A package arrived this week that I thought was going to be great news but it turns out that it’s just complicated the picture. http://forums.pelicanparts.com/uploa...1650290045.jpg I ordered a gallon of pure white single stage paint from eastwood and a tin of Mixol universal dyes with the intention of color matching the white to my car and blending in the body work. I’m a fine art conservator by day, or at least when I’m not avoiding real work to play with the car which lives at my work studio. Part of my job is color matching so I’m extremely confident that I’d be able to hit the target if not the bullseye. The issue is that I started to assess just how many areas I was going to have to blend and it was, uh, surprising; half the hood, the entire driver’s fender, half the driver’s door, both rockers, the tops of both rear fenders, the rear bumper area, the front of the passenger’s fender and a few more small spots…. It seems almost comical to attempt to blend in 50% of the car to paint that’s not quite great to begin with. So, I think I’m repainting the whole damn thing. On one hand I’m pretty despondent that I didn’t’ decide on this from the get-go and strip the whole exterior and go all-in but what can you do, this was never supposed to be a years-long project- if you recall I gave myself 6-7 months to complete everything, and complete it I will. But I’m a big boy and I’ve made this bed so I’m going to eat this cake. I’m keeping the car white but changing the particular white. I think I’ll mix an off white- a lighter, less yellow version of chiffon white, something a bit warmer than grand prix or pure white but not so French vanilla. Oh boy… |
Excellent.
Can't wait to see how it comes out. |
Great work Julian. I've really enjoyed following along.
You are an inspiration!
I couldn’t help but to notice the tag line on your Eastwood products say “do the job right”. Maybe subliminal? Best, Rutager |
I'm literally laying tracks just ahead of the train... I haven't the slightest clue what I'm doing and so I honestly don't know if it's the right way or blasphemy... all I do know is that it's fun and that matters! |
You can keep working on it without getting FOMO - based on the current weather patterns we'll be seeing snow well into May ;)
Haha, well would you look at that….
My humble documentation of not listening to reason, throwing caution to the wind and laying tracks for a rolling train has made it into the top 12 of the Pelican build contest. (Which is funny because I’m so far from done!!) Obviously humbled to be in the company of so many awesome builds that taught me so much (mostly to not just be happy with what is) this is pretty cool. https://www.pelicanparts.com/support/spring2022sweepstakes.htm?utm_source=forums&utm_me dium=post&utm_campaign=promo&utm_content=DIYcontes t |
I have to admit to not following this thread as closely as I could, but just sub'd to it so I'll get the updates delivered right to my inbox. I'll look forward to Saturday updates the same way I do Chris's monday entries! Great job, lots of fantastically creative ideas. Thanks for sharing them! I really like your workspace. I feel like spraying paint in there is going to be a problem? I might get flak for this but it's possible to paint single stage urethane with a brush and a roller. And I'm not talking about all those youtubers wasting a colossal amount of time painting cars with non-catalysed rustoleum (don't bother). The VERY broad strokes (pun intended) would be: - put on lots of paint - sand it flat - polish As an art restorer you'll have an easy time building the relationship you need with the paint to make this work. If you're interested I could guide you along. It would be fun to be a part of it. |
I’ll be honest, I’m tempted to vote for others’ builds too- yours for sure!
The plan for paint is to build an enclosure around the car with 4mil plastic- basically a little spray room. The overhead door will be open and exhaust fans will pull the air out while fans on the other side will bring air in. Before I had my exhausted spray “room” that’s what I did and it was pretty effective. Plastic on the floor is key though! I have a pretty nice HVLP system with an inest awata gun and feel that if I can get the gun dialed for paint as opposed to the varnish I normally spray it *should* cut down on the amount of sanding I need to do. The reality is that I’ll probably be doing a lot of sanding one way or another. Seeing Gabe’s work on the Avocado helps build confidence but I’ll be honest; I’m still pretty anxious about it. |
It's actually convenient to paint a 911 in parts, the biggest one being the roof. You can do a soft edge mask at the drip rail, and paint the cowl and roof as one, each quarter panel/rocker as one, hood, front fenders, bumpers etc. all in batches. I'm a terrible painter, but a great sander. You can adjust your gun such that there's a bit less overspray than there would be otherwise - this comes at the expense of atomisation and the finish will be wavy compared to a "pro" job in a booth. I painted my car twice trying to achieve the surface finish I wanted. The prep for the 2nd round of paint started around page 9 of my build : Quote:
Best of luck, Julian!
I don't stand a chance this time around. (I'm just glad to still be recognized as a DIY enthusiast.) |
| All times are GMT -8. The time now is 10:26 AM. |
