do you shake your oil?
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=1;t=002256
i never thought to shake my oil bottles while doing an oil change. some of these guys say it is recommended. p.s. i found this oil board 2 days ago and have been enjoying it, there is alot of discussion of Walmart Mobil1.... etc. they say Walmart Supertech oil filters are very good they put synthetic oil and additives in their lawnmowers... so, do you shake your oil?????
Unregistered
No, I don't. I can see no reason to shake oil. If there's something in the new oil that needs to be shaken to mix it up, I don't want it in my engine.
If oil seperates while in the can it probably seperates in your oil tank too. Imagine what that would do to your engine upon start up.
sepia 73 T "steamer" |
Non Compos Mentis
My oil gets shaken enough when I autocross.
I do not shake my oil.
I would not use Walmart filters. That site reads like the blind leading the blind (with apologies to any blind people). Jerry M '78 SC |
Information Junky
I always forget; does the 'snake' part of the oil sink, or float to the surface?
TIC
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Ok I read enough "snake oil" quips so I have to ask.
wtf is snake oil? I take it it relates to dodgy fraudulent goods? |
Doesn't everybody use synthetic in their lawn mower? My mower has a Honda OHV engine, is air cooled...after break-in, I switch to synthetic for it's better heat protection.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Information Junky
I thought the worm alway floated to the top? No, I don't shake the oil.
whew.... this thread gives me the "shakes"
shaking up motor oil.... please!!! anything that would settle out in the bottle of the bottle is likely piling up on my sump plate right now.... better go look....
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Certified Pre-Owned
This reminds me of the old wives tale about how you should never let your gas tank run down below a 1/4 tank because it will start sucking up all the dirt and sludge off the bottom of the fuel tank...
Never mind that the fuel pickup is on the BOTTOM of the tank...
'84 Carrera Coupe |
Too many James Bond movies, shaken...not stirred. And I thought the dipstick was for checking the oil level!!
John 86 Coupe - Sold Macan GTS Ducati Multistrada |
Double Trouble
apoligies to blind people? Very PC, but like would they would have someone reading this boards entries to them? Is there a braile version somewhere?
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Jerry M '78 SC |
I forgot to shake the oil first on my last oil change...
really sucked having to shake the car after I was done. Ed '92 C2 Cab |
I can remember back in the 70's some of the new synthectics, especially from a company called EON would separate. Some of the additives would settle to the bottom, you could see it! So shaking wasn't a bad idea with that product.
"This reminds me of the old wives tale about how you should never let your gas tank run down below a 1/4 tank because it will start sucking up all the dirt and sludge off the bottom of the fuel tank... "
Another "old wives tale" was that a tank seldom filled tends to develop rust in the areas not covered with fuel (exposed to air). Hmmm. old wives tale or real fact? Sherwood Lee http://members.rennlist.org/911pcars |
Some guys need the exercise. Seriously, there is no reason to shake new oil. The only "stratification" I can think of would be if you had a bunch of fuel in the oil, such as our MFI systems cause, or if it were wintertime, and you dumped a cup of fuel in the oil to thin it for cold-weather starting. Probably more appropriate to a Cat diesel bulldozer than a 911.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Black and Blue
Like that commercial where the older guy is shaking VIGAROSA 75 at his woman?
Then they show him shaking some kinda motor oil at his classic auto in the garage. If it makes you feel better, shake it up. I think my car really enjoys the foreplay!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
