-   -   Why both springs (http://forums.pelicanparts.com/porsche-911-technical-forum/1106870-why-both-springs.html)
Funracer 11-16-2021 08:08 PM
Why both springs
Why are there two springs here? They both act as throttle returns. My cruise control is gone does the upper spring have anything to do with the missing cruise control?
http://forums.pelicanparts.com/uploa...1637121518.jpg
Jeff Alton 11-16-2021 08:22 PM
Because that is what the engineers thought was required to allow proper pedal feel/response....
smadsen 11-16-2021 08:47 PM
I think you can get whatever throttle feel you want with one spring.
All good systems have two springs in case one of them should break, malfunction, bind up, get jammed with a dirt clod, or disconnect.
Two springs are standard on most race cars and the organizations they run with. Even seen sprint cars with throttle return cable to a hand lever in the cockpit. It looked kind of goofy, but you can bet that lever would shut the throttle plate when all else failed.
timmy2 11-16-2021 10:32 PM
Top one is the strong one. Bottom one is more of a back up.
My bottom one was missing as the tiny tab on the bottom of the intake runner it attaches to was broken off, and I never knew there should be one there for a long time…
wrxnofx 11-17-2021 06:56 AM
My buddy has a '75 that only had 1 spring. Long story short, one end of the spring came off the mechanism and when he pressed the throttle it pegged the engine, and the throttle stayed on the floor boards. So one spring was a single point of failure for the whole car.
panzerfaust 11-17-2021 07:54 AM
Federal mandate in 73 required two return springs... one as a redundant to avoid throttle lock in case one fails.
Funracer 11-17-2021 08:28 AM
Two springs it is then! Might be one of those things to look for if you haven’t seen that bottom one in a while.
3rd_gear_Ted 11-17-2021 09:19 AM
I believe crimped fuel line clamps fall in the same category???
GH85Carrera 11-18-2021 06:06 AM
It is just Belts & Suspenders for possible failure of one.
