High NO on smog test
I have an '87 Turbo. It's stock. I recently took it for its bienniel California smog test, and it passed. Motor was hot, full tank of 91 octane, O2 sensor is hooked up, etc.
But looking at the values, I noticed that NO is at the higher end of the allowable spectrum. HC and CO are well at the bottom of their scales, though. For my own education, what is the cause for this? Is it as simple as the motor's running lean? Please teach me something. http://forums.pelicanparts.com/uploa...1637806228.jpg |
I’d be curious to know too, but at least you passed.
My past experience is that when HC and CO are low, then the NOx is high. Fuel mix can be adjusted to raise the HC and CO and bring down NOx. I assume your Turbo has CIS. You can hook up to an exhaust analyzer and adjust the values.
Your engine is running too hot. Probably a little lean.
NO is a product of higher pressures during combustion. You only knock it down by reducing power or by using a three way catalytic converter. (The original 2 way catalysts didn't deal with NO and NO2.)
In the 80s Motronic Carreras they have a brown jumper wire that made the system retard the ignition by 4° to reduce the combustion pressure specifically to reduce NO for California's emissions. (So yeah, we disconnect the wire when it was time for a smog check.) |
Ivan |
This chart is helpful To see how they interrelate. http://forums.pelicanparts.com/uploa...1265170114.jpg |
http://forums.pelicanparts.com/uploa...1640323849.jpg
My 86 carrera a couple weeks ago, I live in a “non enhanced” zip code (desert) No no |
EGR problems can cause high NOx, too. IIRC, 930's had EGR on both CA and FED cars.
It's still not terribly high. I'd be more concerned if it barely squeaked by. |
| All times are GMT -8. The time now is 06:25 AM. |
