83 911 diesels when shut off
I have a 1983 911 3.0 that diesels and is close to backfire when I shut it off. Starts and runs really well. What could be the cause?
Old 11-30-2021, 06:34 AM
proporsche's Avatar
check your fuel mix..and what idle speed do you have it ?
When was the last time you have checked the distributor timing?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-30-2021, 06:47 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Carbon on the pistons. CR (compression ratio) is too high and or too high temps. Higher octane gas should solve the problem.
Chris
Old 11-30-2021, 01:51 PM
Poopwink's Avatar
I've also experienced this intermittently in my '85 with stock 3.2. Distributor was recently serviced by respected marque-specific shop. Starts and runs like a dream, even in cold temps, but every now and again it continues to run for a very brief period after turning the key off (<1 second). I'm running 91 octane (ethanol-free). 307micheals, what fuel do you use?
Old 11-30-2021, 02:11 PM
It's called post ignition not diesels.
Old 12-01-2021, 06:52 AM
