-   -   3.2 Carrera FI on a 3.0 SC engine (http://forums.pelicanparts.com/porsche-911-technical-forum/1107872-3-2-carrera-fi-3-0-sc-engine.html)
mmascari 12-01-2021 04:40 PM
Will the 3.2 fuel injection work on a 3.0 motor? I have a 3.0 engine with PMO carbs and would like to go back to fuel injection.
AlKidd 12-01-2021 04:46 PM
I believe so if you use an aftermarket FI system like Megasquirt. 3.2 intakes seem to be quite difficult to source
faapgar 12-01-2021 04:48 PM
3.o
If you have an 83 SC 3.0 from the second half of the year it is pretty easy.That engine has the 3.2 case with no sump plate and the bosses for the flywheel pickup sensors.The heads have the spot machined for the cylinder head temp sensor as well.Or go back to CIS.
