Thermo time switch
I am working on a friends 83 SC and found the wires to the thermo switch ripped out of the connectors. I have looked at the wiring diagram and can’t figure out which wire goes to which connector. There is a yellow wire and a red/black wire, one goes to a small connector and one to a larger connector. Could someone please look at their thermo switch and tell me which is which? The switch is in the left chain housing cover. Thank you.
Yellow (G) sm
R/blk (W) lg The G&W are on the porcelain just under the connectors. |
Thermo time switch
Thank you gled49, I now see the markings. Kevin
