75 door window guide replacement
On my 75 911S, the door windows are manual and there appears to be two different pieces. There is window channel (soft rubber) and window guide (metal and felt). Do you use either, or both of them?
Thank You in Advance! |
I have a 71 911T with parallel arm regulators. The windows use both the channel (lifter seal) and the guide.
| All times are GMT -8. The time now is 02:23 AM. |
