Stock antiswaybar size?
Any one know what the stock front antiswaybar size is off a 73 911e, and a 70 911t? Will weltmeister adjustable ends bolt onto the smaller stock bars? I have too much understeer with my 19mm front and like my car loose for autoX. Current config. is 18.8mm front torsion and 19mm weltmeister swaybar, 26mm rear torsion bar with 22mm weltmeister swaybar. My other choice is to go with a bigger (Swayaway?) rear bar.
ThanksSmileWavy |
I tried a 19mm front sb and got to much "push" so I went back to the stock 15mm. The car cornered alot better especially on a tight a-x course. I also went from an18mm rear bar to the stock 15mm
sway bar. Kevin 72 911T/E |
| All times are GMT -8. The time now is 04:30 PM. |
