Which engine do I have?
This is a rather odd question , but I recently purchased a '76 911S targa and I'm trying to figure out if a previous owner may have done an engine swap to a 3.0. So how can I tell if it's a 2.7 or a 3.0?
Thanks in advance,
Jon
Old 05-15-2003, 03:10 PM
Hilbilly Deluxe
emcon5's Avatar
Post the engine number, someone can decode it for you. It is located at the base of the fan on the right side.
Tom
82 911SC Coupe
GTI Cup #43
Old 05-15-2003, 03:19 PM
Senior Member
Superman's Avatar
A 3-liter case is made from aluminum. The 2.7 case is made from magnesium. Magnesium is quite grey and oxidizes easy. Even on a 3-liter, the fan and fan housing are magnesium.
The 3-liter case would be shinier, or at least shineable. Yes, you can shine magnesiu, too, but not like aluminum. Also the 3-liter engines used an orangish-red shroud.
Mocha 1978 911SC. "Coco"
Non Compos Mentis
You could always disassemble the motor. The 2.7 used 90mm pistons, the 3.0 used 95mm.
Let us know what you found, and how long it took to put it back together.
Old 05-15-2003, 04:06 PM
Free minder
Aurel's Avatar
HAHA ! That was a good one, Dantilla.
You could also drive the engine hard for 50,000 miles, and if it breaks down, you will know it was a 2.7...
Count the blades on the fan, if there are only five, it is not a 3.0.
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 05-15-2003, 05:38 PM
Just try to torque the lower head studs. If they spin like they are stripped out of the case, then it's a 2.7L. If the studs are broken, then it's a 3.0L.
Rob
1980SC
Old 05-15-2003, 06:26 PM
